Tims Web Site
Date:  11-29-2015
Number of Hours:  4.00
Brief Description:  Seperated control lever parts
Seperated control lever parts. As per plans, cut to length the control pushrods for the elevators. Match drilled the bell crank parts for the elevator. Scotch brite all parts, alumi-prep, alodine, and primed bell crank, pushrods and push rod ends. Assembled pushrod parts. Marked described hole pattern. Drilled and clecoed together.
Elevator pushrods and forward conrols
In place pushrod ends/Bell crank
Clecoed ends to elevator pushrods
