Tims Web Site
Date:  11-12-2015
Number of Hours:  4.00
Brief Description:  Mounting bracket for Andair Fuel Valve
In the Quick build fuselage, the standard fuel valve bracket was already iinstalled. I removed the bracket and modified to accept the hole alignment of the Andair fuel valve. I then fabricated another forward bracket from 3/4" aluminum angle to support the front hole in the fuel valve. I drilled the new bracket to accept nut plates and screws just like the oiginal mounting plate in the rear. I made a card board template to get the measurement needed for installation of the aluminum cover plate with the left and right tank markings.
Forward fuel bracket
Cover plate drilled to accept tank selection cover
