Brief Description: fit and paint pitot tube assembly
The pitot and static inlet probes are fabricated into a single unit that is mounted through the leading edge of the left wing. The unit is fabricated at the factory, but need to be fitted and finished prior to final installation.
I fitted the assembly to the wing, drilled the holes for the attaching hardware, then removed the assembly and took it home to paint.
