Brief Description: Page 283 Wiring for a Viking Part 7
July 15 2013
The Viking suggested wiring of the engine :
Negative (GND) Side:
1) Install #10 cable between each battery negative terminals 2) Install #10 cable from each battery to airframe ground / Grounding bus 3) Install #6 cable from each battery to engine ground. Be sure to strain relieve cables before leaving engine and battery 4) Install 2 switches to ground on panel for closing of contactor to select battery. Use individual wires to separate grounding studs for safety.
I ran the 2nd ground wire from the 2nd battery to the Avionics Tray
I connected the ground wire to the ground lug and then another ground wire and ran it to the bulkhead
I connected the ground wire to the lug and connected the last wire to the lug and ran it up the arch
