TAB Aircraft LLC Web Site
Date:  6-27-2013
Manual Reference:  N/A
Brief Description:  Page 269 The Power Run
June 27 2013
The Power Run
I made my first battery to contactor wire using the Super 8 copper clad aluminum wire which is a 6 awg wire, the new wire PA is using.
http://www.periheliondesign.com/fatwires.htm
Since I do not have crimpers for this size wire, I had to solder the wire to the lugs and cover with heat shrink tubing.
Right battery to right contactor, left battery to left contactor to 60 amp fuse holder to Dynon Shunt. The Power Run.
The first battery wire
The Power Run
The Power Run
