The Avionics Tray was taken up by Dynon stuff and I need a place for all the Battery stuff so I got a piece of wood saved from packaging brace for the aluminum I got from Aircraft Spruce.
I covered it with fiberglass and glassed it to the hull.
After it cured, I attached the Parking Brake Valve. I then installed the two Battery Contactors, Main Fuse and Dynon Shunt.
Covered it with fiberglass and glassed it to the hull.
Attached the Parking Brake Valve.
Two Battery Contactors, Main Fuse and Dynon Shunt.
