TAB Aircraft LLC Web Site
Searey LSX
N/A
Page 262 Installed Heater
June 7 2013 continued.
Installed Heater
I took some 1" aluminum angle and measured, cut and bent to attach and tilt up the heater.
I made the connector angles on each side and attached it to the hull stringers under the Avionics Tray.
Bent the angle to make it tilt up
Searey LSX Home
800
Aircraft
Airframe
86
Background
Brakes
Cockpit
67
130
Education
Exterior Trim
Fly-In/Party
Gear Assembly
Hull
Interior Trim
Modifications
Turtle Deck
Wiring
53
131
Work Shop/Hanger
