Brief Description: Page 64 Brake Line Routing Part 2
September 10 2012
After I fed the 1/4"OD Tubing through the Gear Leg, I attached the tube to the bolt that connects the Axle to the Main Gear Spindle Mount with a Clamp. I had to increase the bolt from a AN4-15A to a AN4-17A to get a Washer, Clamp, Washer, Spindle Mount Front, Axle, Spindle Mount Back, Washer and a AN4 Bolt on it. I then fed the smaller Brake Tube through the 1/4"OD tube till it came out the othe side. I ran the 1/4"OD Tube to a 1/2" from the Brake Connection and connected the smaller Brake line to the Brake.
