Brief Description: Page 38 Cut the Gear Leg Opening
August 11 2012 Continued.
Cut the Gear Leg Opening Manual Ref: S5- 14.1 to 14.5
Measured and marked the Hull to cut the Gear Leg Openings.
I did not like the cut I made in the Hull for the Bulkhead. Since I needed to make up fiberglass resin the coat the exposed foam in the Gear Leg Opening, I decided to patch the gap in the Hull at the Bulkhead. I taped around the Bulkhead and pilled the Airframe and laid Fiberglass resin and glass on the tape. I also coated the foam in the Hull opening.
