Brief Description: Page 37 Drilling the Hull Stringers
August 11 2012
Section 5. Installation of Airframe into Hull Manual Ref: S5- 12.1 to 13.5
After I sanded the fiberglass work I did on the Stringers, it was time the drill the holes in the Stringers to mount the Airframe. I shimmed the Airframe to get the bulkhead level with the top of the Hull. I marked the Bracket holes and lifted the Airframe and drilled the holes. I reset the Airframe and tried to install the bolts. They did not line up to good so I had to drill through the brackets and the Stringers.
