TAB Aircraft LLC Web Site
Date:  8-3-2012
Manual Reference:  N/A
Brief Description:  Page 35 Test Setting the Turtle Deck
August 9 2012
I had cut the holes on the Turtle Deck to test the fit after the Airframe was set into the Hull. I wanted to see if the Airframe was set deep enough in the back that the Turtle Deck would sit on the hull in the back. However I did a terrible job on the cuts and made them to big. Now I have to Fix it so it wont look so bad
Aft Hole
Aft Hole
Forward Top Hole
Forward Top Hole
