I set the Airframe into the Hull again to check the fit again. I had to elongate the holes on the front channel brackets under the rudder peddles to get it to fit, but it all worked out. Now I have to drill through the mounting brackets into the reinforcements on one side and hope it hits the holes on the other side of the Stringer. But not tonight. Called it a night.
