Brief Description: Page 30 Airframe to Hull Stringer Reinforcment
August 7 2012
MODIFICATION NUMBER 5
Airframe to Hull Stringer Reinforcement
After the Hull Reinforcement was done, it was time to do the Stringer Reinforcement. I had to set the Airframe into the Hull to get the locations of the mounting points. But the Airframe would not set low enough in the Hull. I tried notching the front Stringer, but it still was to high. I called Alan Chandler at Progressive, and he measured the front stringer of a kit being built there, and said it should be 6" high from the center Hull Seam. I measured mine and it was 7". Now I have to do some cutting.
