Brief Description: Page 28 Gluing the foam to the Hull
August 2 2012
I mixed up 4oz. of resin and a mixture of 4oz. resin and Fumed Silica to make a resin paste to glue the foam to the Hull. I brushed the resin on the foam and spread the paste on the Hull and put the front right foam on the Hull and placed weights on it to hold it to the Hull. I started on the top right foam when both the resin and paste started to gel up. I mixed up another batch with a little less hardener and finished. After the foam set up, I mixed up a batch of paste and filled the gaps in the foam.
