Brief Description: Layout drill holes on lower cowling
Lay out rivet holes on lower cowling for hinge. Made the hole locations 1" apart. The hinge half will be installed with an upward bias toward the back of the cowling to make the removal of the upper cowl a lot easier. It took a little time to make sure there is enough edge distance both for the fiberglass and the lower hinge half.
