Continue working on the static air system. I decided to use the Nylo Seal 264-N04 connector instead of the 3/16" plastic Tee. The Nylo Seal Tee is a lot sturdier and better quality, it will provade trouble free connection. Install the Nylo Seal connector, cut the 1/8" clear plastic tube to the proper length and slip both ends over the protruding end of the rivets. Measure the required length of the 1/4" NyloFlow tube, install it on the 264-N04 connector and temporarily run it forward to the instrument panel. Install the 1/8"/1/4" tube on the connector tee. Drill two #30 holes on the left side of the fuselage bulkhead and use 4 ply waxed strings to tie the 264-N04 connector tee to the bulkhead. This turned out very sturdy.
