Use E6000 Adhesive to seal the 1/8" clear plastic tube at the sides where it fits over the rivet ends. I also applied small dabs of E6000 along the flange of the bulkhead to steady the clear plastic tube. Run the 1/4" plastic tube along the longeron to the instrument panel. I clamped this tube between the F-706 and F707 bulkheads and applied a small dab of E6000 between the F-707 and F-708 bulkheads to support the tube. The static air system turned out really nice and sturdy. Tried to rivet the F-787 stiffener web/F-707B Angle Clip assembly to the F-707 bulkhead, but due to tight quarters I had to use two screws (AN526-6R6 Screw/AN936-A6 washer/AN365-632A nut) instead.
