Brief Description: Finish left wingtip wiring, start on right wingtip
Cleaned up the position light and strobe wires. Installed the coax connection for the NAV antenna. Started the right wingtip wiring by installing the coax cable for the COM antenna. Started the wires for the position light. The process is very similar as I described for yesterdays work.
