Brief Description: Finish installing the right wingtip wires
The same basi procedure had to be followed as on the right wingtip. I enclose the text in "" from the left wing write up: "I installed the wiring and connectors for the left wingtip. Had to un-install the connectors for both units. They came installed from the factory. Then I followed the plans in the installation manual from Bob Archer. This was a tedious job because the wires (#18) had to be extended and access was quite limited. The idea was to separate the antenna and wingtip light wiring to elliminate interference. The included picture shows the wire runs. Also I placed the wingtip close to the end of the wing to measure the wire length for each wire." The only difference from the left wing is that the antenna is the COM antenna and it is installed at an angle. I changed the procedure a little by rewmoving the strobe light with the wires and extending them on the bench. Why didn't I think of this before.
