I installed the wiring and connectors for the left wingtip. Had to un-install the connectors for both units. They came installed from the factory. Then I followed the plans in the installation manual from Bob Archer. This was a tedious job because the wires (#18) had to be extended and access was quite limited. The idea was to separate the antenna and wingtip light wiring to elliminate interference. The included picture shows the wire runs. Also I placed the wingtip close to the end of the wing to measure the wire length for each wire.
