This was a very frustrating day. Nothing seems to work. I realized the down elevator stop has to be trimmed (actually Russ came by I told me he had to do the same thing). As it was installed on the Quick Build fuselage it will give me only 8 degrees elevator travel. The up elevator travel is 28 degrees. So I had to call Barb to come out and help me take off the elevators (this is not a one man job). This was also necessary because the up elevator stop (F912D) will have to be riveted. The elevator horn will make this impossible. Should have thought of this before I attached the elevator. I actually had more hours, but totally unproductive and frustrating,
