Clamp the counterbalance arms to the stabilizer to set nutral elevator position. Temporarily install a bolt trough the push rod and the elevator horns. Make a preliminary check of the nutral position at the F635 bellcrank and the pilot stick. Tomorrow I will make more accurate measurements. Deburr, clean and prime the two F824B cover plates. Deburr, clean and prime the F912D angle.
