Installed the flanged bushing as a part of the Cyclic Control System.
I drilled the required holes in S01-480-4008-03 Walking Beam. Orginially, I did not have the drawing but Dan Banks provided an PDF for me.
I did some work on the PVC for the EJ25. I had purchase the PVC hoses setup off an salvage engine. I block one of the two ports on the reducer with glue because I will not run a hose to the air filter box (as done on an automobile). I took one of the 90" holes and put that on the PVC valve and need to connect a length of 5/8" ID hose between the block port and the 90 degree hose. It will be routed over the top of the intake manifold.
