Recently, while mounting the lower sprocket a bolt behind the flywheel into the mule collar jammed and had to be cut off. In order to remove the cut bolt, all the bolts on the PSRU and prerotator needed to be removed.
I did so and reinstalled the PSRU with new bolts for the mule collar. Awaiting the machine shop to remove the piece of the bolt stuck in the collar.
