Brief Description: Wire harness and mounting relays
Mounted a small sheet of plywood on the pilot side for attaching terminal strips and the strobe box.
Begin routing the engine wire harness down the cabin and to the locations where the ECM connector begin to branch off. The plastic conduit was too stiff at the appropriate locations, so I remove a section of the conduit so the circuit branches could go where they need to go.
Mounted the Engine Relay and Fuel Relay on the pilot side.
Made a bracket for the speed simulator and mounted it on the passenger side.
