Brief Description: Replace bolts on prop horse collar
I had the bearing sleeved on the prop sprocket and discovered that needed to install it with bolts with holes in the head for safety wire. To do that, the PSRU assembly needed to be removed because the bolt holes are behind the engine ring gear. Once the new MCM C-91286a999 were in place, Brian and I began assembly of the large sprocket with the 'mule shoe'. However, one the special bolt froze solid so we ended up cutting the bolt to free the assembly.
