Brief Description: Panel mount with ECU and SkyDat Gx2 mod
I fashioned an electrical panel out of 3/4" oak plywood. To attach it to the cabin without have long bolts, I cut two strips on 2024-T4 strips and attached them to the top and bottom of the board.
I cut rubber donuts to cushion the AN3-5 bolts between a washer and the cabin on the outside. On the inside, I cushion the cabin from the 2024-T4 strip with another rubber donut.
Then I attached the ECU and SkyDat GX2 module based on the SH3 plans.
