The fuel return line was hard bent to route over the torque tube and still connect to the barb fitting in the Pilot fuel cell. I purchased a 5/16" x 1/8" barbs and 90 degree 1/8" block to make a 90 degree barb fitting. I cut a 1/4" off the fuel cell barb and one of the 90 degrees barb so they would fit between the torque tube and joined them with short piece of hose. Of course, I did not have the right clamps, so off to the store we go. Then I attached the fuel return line to the remaining barb fitting.
I also replaced the 1/4" terminal spade on the 12v socket in the instrument support with one designed for the wire. Much better fit.
