Steves Web Site
SparrowHawk I
Fuel Level Sensor and Battery Tie Down
I prepared the battery Tie Down for paint. Cleaned with MEK and sprayed with etch primer. Then applied a coat of black paint.
I cut two lengths of clear tubing for the battery tie down rods hoping this will help the corrosion control.
I installed the fuel quantity sensor using ProSeal and 10-32 SS bolts. I did not install the assembly until I can do an electrical check.
Fuel Quantity Sensor -inside
Fuel Quantity Sensor -outside
Battery Tie Down holder
SparrowHawk I Home
784
Cabin
Exhaust
Heater
Rotor Head
Wheels
