I discovered I set the flight controls to 2 degree right instead of 2 degree left. I swapped the left and right upper control rods but the did not fix the problem so Dan and Justin helped me redo the entire rigging process again.
Justin made the compass mounting bracket.
Dan worked on the fuel tank level sensor.
Justin and I greased the prerotator casing and drive and installed it.
