Completed drilling the two 1/4" holes that should have been in the keel for the Rotor Brake Handle. (For some reason, no pilot holes were completed at the factory.)
Attached the brake knob to the brake lever. Attaches the actuating plate to the forward most hole in the forward keel. Attached the brake lever to the aft most hole.
Since I did not have the cable ready at this point, the brake levers were loosly installed. However, I had a metal spacer instead of a nylon one. The spacer is too long to allow the brake lever to line up. I will cut the space to size after I install the cable.
