When I installed the Horizontal stab, I marked the location of the 1/4" hole on the Vertical Stab. However, when I went hunting the location of the stab using a drill with tiny bit, I forgot I drilled to hole in the spacers and not the HB tube. So I drilled around several places expecting to find the hole in the spar (which there is none). I so need to patch up those holes.
Once I realized my error, I drilled the 1/4" holes correctly. However, when I received the replacement tail, I did not receive the bolts. Aircraft Spruce loves me. I ordered the parts tonight and will finish it later.
