Repair or replaced nut plates stuck with epoxy. One nut plate did not line up correctly with the instrument panel, so I removed it, filled the rivet hole with boat epoxy & fiberglass dust.
Finally purchased the correct pre-rotator belt after trying 10 others! It is a NAPA 25-060439
