Steves Web Site
SparrowHawk I
Cut Instrument Panel
Cut the instruction panel for the DX2. I used a air cut off circluar saw and hand filed it to final shape.
Assembled the Pod support structure and riveted it. I used the plans description of a 5'8" pilot so I cut the length of the square tubing to 9.5".
I glued the 1.5" square alum blind nut plates inside the Pod using marine expoy and glued the fender washers all at the same time.
Pod Structure
Pod mounted
Expoyed blind nut plates
SparrowHawk I Home
784
Cabin
Exhaust
Heater
Rotor Head
Wheels
