Steves Web Site
Date:  2-19-2009
Manual Reference:  Cyclic Control
Brief Description:  Flanged Bushing Installation
Installed the flanged bushing as a part of the Cyclic Control System.
I drilled the required holes in S01-480-4008-03 Walking Beam. Orginially, I did not have the drawing but Dan Banks provided an PDF for me.
I did some work on the PVC for the EJ25. I had purchase the PVC hoses setup off an salvage engine. I block one of the two ports on the reducer with glue because I will not run a hose to the air filter box (as done on an automobile). I took one of the 90" holes and put that on the PVC valve and need to connect a length of 5/8" ID hose between the block port and the 90 degree hose. It will be routed over the top of the intake manifold.
Block vent to PCV
Block vent to PCV
90 degree hose on PVC valve
Blushing installed to dry.
