I plan to determine all the things that may modify the cabin before I sent it to the paint shop. The heater would require two holes to be drilled for the water holes. However, per the instructions, one hole is 5" above the keel. That location is inside the gas tank!. I called Dan Banks and he told me to follow the drawing instead of the instructions. The drawing shows that the bottom water hose is 5" above the gas tank.
