Brief Description: Engine Starter and Door handle Fitting
After installing the new PSRU plate, the starter still seems to not engage the ring gear and makes ringing sound. As an experiment, I made a spacer between the starter and the PSRU and it seems a little bit more effective. As a work around, if I click the starter switch, I can tell if the starter will engage or not.
I fixed the orientation of the outside door handles to line up with the air stream in the lock position.
During the engine test, the engine always 'catch' immediately (i.e., starts immediately).
