I mounted the PSRU and when I went to hang the Prop, I had forgot to insert the top 2 mule shoe bolts that are not accessible because of the ring gear. So I undid the things I'd done. Then redid the things I did.
During this process, I compared the PSRU to the original one and they were identical. Both had a tag S01-620-4000-03 REV L LOT 4780. I'm not sure this will fix the starter hitting the ring gear. If not, I will drill a larger hole in the starter bolt location and move it slightly to the port side.
I opened the fuel tank to check the fuel sender (Innova #7982 0-90 ohm). I do not have a lot of confidence in it performance. It worked outside the tank. Failed in the tank to change values. Now it is working but who knows how long that will last.
Once I safety wire the mule shoe bolts, I back to the point to run the engines again.
