I completed the wiring of instrument panel breakers and made a bracket to hang the panel 90 degrees to th pod so I can attach the power and grounds.
Realizing I had not run the rotor tach sensor wires down from the mast yet, I grabbed the ladder and riveted the 1 inch square wire mounts to the mast and then wire tied the cable down to the point where the engine harness enters the cabin. Tomorrow, I'll drill a hole for the wires and seal it again.
