I had installed (3) 3 amp circuit breakers on the instruction panel and needed to replace one with a 2 amp breaker. The swap out also changed the spade connector to a terminal connector, so I needed to swap the initial wirings. The new breaker also required a larger hole in the panel, so I enlarged it also.
