Continue with small adjustments to find a better position. With straps holding canopy down and rubber sealing installed in front I found a position that can be used. The fairings 6-C-3-62 will maybe not be perfect positioned, I would have prefered to cut out the slot for rubber sealing my self. Now the slot is too much forward. If nessary I will fabricate a new pair.
