I start to carefully cut some slices at canopy rear end, and tried to figure out right position. After removing material from front end, 2-3 slices, there was space enought to insert upper skin again. Temporary with clecos. Canopy lies now on two flat iron bars, fixed to upper longeron. A final cut was made at the white mark on canopy front. Next step, try to find a correct position fwd/aft. I measured and drilled a hole in each side, forward position. Than connect the canopy temporary to structure with clecos. Rear fixation point was on top of arches. Next item was to connect to rear skins. But canopy is still too high rear. There will be more adjustments...
