Today is the day, I have to make the cut. A simple job but it can be hazardous. I laid the cut just in the middle of the two arches. Removed rear canopy and moved the front canopy as far forward as possible. Fixed the front part as low as possible on both sides. With start from top of canopy, I drilled all rivet-holes in plexiglass at forward arch. Mount it with clecos together with center canopy strip 6-C-3-53. Continue drilling holes at sides of canopy, and fixed the canopy to the arms with clecos.
