Continued to assemble the elevator. Installed 6-T-3-5E , 6-T-3-5mod and 6-T-3-8. Had to remove 1 rivet on upper side, it was installed too early. Installed 6-T-3-11 on lower skin. Continued with the trim hinge, rivet to elevator. Temporary installed elevator to stabilizer, with cleco. Think it is a good idea to rivet fiberglass tipĀ“s later, when stabilizer are installed to fuselage. Trim motor, rod and cover plate will also be intstalled later on.
