Sonnys CH650
Zodiac CH650
Dwg 6T4
Upper Rudder Bearing
Marked out the two bearing halves per print. Cut 85mm lengths using power miter saw then cut angles with hack saw. Sanded and filed rough edges. Match drilled 3/16" holes.
6T4-3
Zodiac CH650 Home
545
Ailerons Flaps
51
103
267
Materials
MISC
Mistakes/Deviations
Research & Planning
Services
Tools & Jigs
Work Area
