Had some concerns about elvator trim extension cable pin outs, so I pullled elevator trim and verifiied connections. Good thing, one had come loose, so I remade the CPC connector using D-sub pins and repinned the cable to match the color coding better. Added nutplate to adel clamp holding ELT wires snug for ease of maintanence.
Then continued routing TCW trim cable forward through the tunnel using adel clamps to secure and prevent interference with the rudder cables.
