Brief Description: Forward fuselage and overhead console
Attached forward fuslage and nothing lined up correctly. Remove panel and reinstalled- forward fuselage fit. Panel needed some trimming around the outer edge. Finally got nice fit. Trimmed former lower panel part to form left and right panel attach points. Clamped and drilled panel screw holes into attach points.
Using 2 inch hole saw, cut air vents into overhead panel
