Brief Description: Doors Day #11 - removed and started lock
Removed both doors from cabin cover. Squared door edges with belt sander. Started process of filling cabin cover door openings to make corners square.
Began working on door locking mechanism. Will be using Planearound's center door locking mechanism. Started with outside handles and drilled 13/32" hole concentrically thru handle. Then drilled #29 per plans thru outer and inner door handle, Deburred holes and then shaped leading edge of handle. Drilled fwd hole to #19 and tapped aft part of hole for 8-32 screw. Countersunk hole for flush 509-8R14 screw.
