Got about 20 misc parts primed- inside of flap tubes, aft vent connections to bulkead, rudder cable links, and side channel gussets.
Installed the WD-1010 control coloumn. Attached the elevator pushrods to the elevator idler arm. Worked on fitting the WD-1011L+R control bases and bushings to WD-1010 control coulmn.
