Clecoed the F-1024 L+R seat floors in place. Match drilled #40 and #19 the nutplate holes in each piece. Then match drilled #30 the remaining holes except aft row.
Cut two 16" long pieces of AN257-3 hinge. Removed pin andset other half aside. Marked and drilled intial hole per plans. Match drilled remaining holes from the F-1022 L+R baggage floors. Clecoed baggage floors in place with hinge installed. Final drilled,deburred, and dimpled the #30 holes in the F-1023 L+R baggage floor angles. Clecoed these parts in place.
